Chrillthesill
Sep 21, 2022Aspirant
Is it possible to add 5 or more satellites (RBS850)with RBR850 router
Hi, Í´ve bought 5 satellites to my AX6000 router, but when Iam trying to connect the fifth satellite it turns magenta, and wont connect to the router. I know that Netgear says that the recommended nu...
- Sep 24, 2022
Glad thats all it was.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Chrillthesill
Sep 24, 2022Aspirant
Hi everbody,
I`ve now solved the problem together with Netgear support. Netgear had sent me a satellite with an old firmware. Now everything works and I´ve 5 satellites connected (3 wired and 2 wireless). Thanks for all the help.
/Chrillthesill
Sep 24, 2022Guru - Experienced User
Enjoy. 📡
