Koesbeenian
Dec 07, 2023Tutor
Is it possible to add a RBS850 as satellite to Orbi 970?
I have a X6000 Router RBR850 with 4x AX6000 Satellite RBS850.
If I buy the Orbi 970 3-Pack, would it then be possible to connect the existing 2 AX6000 RBS850 as satellites to the Orbi 970?
At...
schumaku
Dec 07, 2023Guru - Experienced User
Which Orbi routers and satellites are compatible? ... in my reading and understanding: No.
