Burp
Nov 15, 2021Aspirant
Is it possible to add an extra RBR850 as a satellite in my existing network?
Hi all, I've a RBR850 router with 4 satellites (RBS850). No DNS issues after the last FW update and I'm really happy with my system and performance. Yesterdag I bought a second hand router and satel...
- Nov 15, 2021
Not with the Orbi AX series.
You can use it in AP mode as a separate wifi signal or keep it as a back up JIC something happens to the other RBR.
Nov 15, 2021Guru - Experienced User
