Feyroce's avatar
Feyroce
Is it possible to hide the wifi network SSID on a Orbi RBR860 router?
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello @Feyorce,
    Welcome to the NETGEAR Community!
    There is no option to hide the SSID on your RBR860. Hidinng the SSID on your RBR860 will not increase the security on your RBR860. There may be another option available to resolve the issue that you are experiencing. What is the reason why you would like to hide your SSID?
    Best,
    Kevin
    Community Team
  • CrimpOn's avatar
    CrimpOn
    No.  The original WiFi5 Orbi had that feature, but it was never available on any of the WiFi6 routers.
    Not broadcasting the WiFi SSID was a popular security measure a decade ago.  It no longer is.
    If there is a reason to want to hide the SSID, there may be other solutions than hiding the SSID.
