Evangelist
Jun 29, 2020Tutor
is it worth upgrading to wifi 6 from wifi 5
Im using the RBR50v2 sytem with 2 satellites in a 3 storey house over 3000 sq feet. Have 200 mbps broadband speed. Getting over 200mbps nearly everywhere and even at the end of my garden-about 8...
- Jun 29, 2020
Its not really going to get you any better speed or coverage if you're already maxing out your speed and able to provide the coverage you need.
I'd hold off if it was me.
Evangelist
Jun 29, 2020Tutor
thanks for advice. maybe ill hold off then.
Jun 29, 2020Guru - Experienced User
Advantages is if you do have AX supporting devices.
