Francisco1202's avatar
Aug 21, 2020
Is ORBI RBK752 region locked?
Hi,
Im considering buying the netgear orbi RBK752 in the US, but i want tou use it in Peru (south america), and i wanted to know if there is some sort of region lock for the product, or if it is only going to work in the US.
Thanks
1 Reply
  • FURRYe38's avatar
    When you log into the RBRs web page, do you see a drop down under the right upper side under the FW version display? Select this AUTO and you should see a drop down menu. Can you select something close to your region here?
