megadub
Aug 26, 2021Tutor
Is RBS350 compatible with RBR850
Hi, I need to expand my installation as the router is to one side of the house and the satellite to the other side and one floor bellow... I'm too often disconnected. BTW, the satellite is ver...
- Aug 26, 2021
350s are not compatible.
EX 7500,7700 and 8000 are along with EAX80.
megadub
Aug 26, 2021Tutor
I do not really know the dimension but we have 170m2 on 2 floors with the router upstairs in one side and the satellite on the opposite downstairs. Let say, something like 30m length + 3m high... so, almost 100f with a floor between.
I'm looking at an EAX80, a bit cheaper and seems to be what I really need.
Aug 26, 2021Guru - Experienced User
- megadubAug 27, 2021Tutor
Finally, I build the network with RBR850 -> RBS850 -> EAX80 and it looks super efficient :)
- FURRYe38Aug 27, 2021Guru - Experienced User
Glad you got it working. PBe sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- megadubAug 27, 2021Tutor
Excellent advice, it's done :D
