megadub's avatar
megadub
Tutor
Aug 26, 2021
Is RBS350 compatible with RBR850
Hi,   I need to expand my installation as the router is to one side  of the house and  the satellite to the other side  and one floor bellow... I'm too often disconnected. BTW, the satellite is ver...
  • FURRYe38's avatar
    Aug 26, 2021
    350s are not compatible.
    EX 7500,7700 and 8000 are along with EAX80.
