MixMaster
Feb 19, 2021Apprentice
Is The RBK True Mesh?
As I determine if I should add an additional satellite to my new RBK853 setup I've seen some posts suggesting that the RBK isn't a true mesh network. If I were to add an additonal third satellite do...
- Feb 21, 2021
MixMaster wrote:
Furrye38,
Thanks again for hand-holding while I get this up and running. Very much appreciated! I've tried opening tickets with Support but it's been non-existent so thanks to you and this community for working thew issues. If I may, a couple of quick questions:
1) After logging in to the RBR the Basic dashboard shows Internet status as "Good". Is that the best level or is there an excellent? I'm just trying to gauge the best performance. I believe "Good" is the only indication or Good and Or any kind of excellent connections. I don't think NG offers up a Excellent inidication. Mines only shown GOOD.
2) Are there any good statistics I can pull that will indicate the backhaul status? Coming from the Linksys world I always relied on their "Spot Finder" as well as Upstream / Downstream levels. You can check the RBRs web page under Advanced Tab and Select Show Statistics which gives a numerical value of connection rates and status.
3) Is there any way to extend the amount of time before I have to re-login to the router? It's way too short.
What browser do you use? I noramlly don't see any problems with the duration, however some browser may behave differently. I mostly use MS Edge or Opera GX here. There is no setting to adjust the web page time out.
MixMaster
Feb 21, 2021Apprentice
Furrye38,
Again, thanks for all of the effort.
Best,
Rick
Best,
Rick
Feb 21, 2021Guru - Experienced User
MixMaster wrote:
Furrye38,
