tabishop
Dec 10, 2021Aspirant
IS THE RBKE963 COMPATIBLE WITH RBS 850 AND 750 SATELLITES?
I have an RBR850 with several RBS850 and RBS750 Satellites. The coverage is good not great and some of the satellites are hard wired in outbuildings. I would upgrade to the new RBKE953 if I could s...
- Dec 10, 2021
Orib 7 and 8 series RBS will not connect to the Orbi 9 series system.
Dec 10, 2021Guru - Experienced User
They are not compatible.
- tabishopDec 10, 2021Aspirant
Appreciate the quick response. Are you saying that the Wifi6E signal won't extend to non-wifi6e satellites or the satellites won't talk to the wifi6e router even for the 2.4ghz signal used by cameras etc.?
- FURRYe38Dec 10, 2021Guru - Experienced User
Got it. Thanks! Too bad Netgear makes it so expensive to upgrade. My next system will be an Eero, even though it's not as good, it will be more affordable to maintain.
