tabishop
Dec 10, 2021Aspirant
IS THE RBKE963 COMPATIBLE WITH RBS 850 AND 750 SATELLITES?
I have an RBR850 with several RBS850 and RBS750 Satellites. The coverage is good not great and some of the satellites are hard wired in outbuildings. I would upgrade to the new RBKE953 if I could s...
- Dec 10, 2021
Orib 7 and 8 series RBS will not connect to the Orbi 9 series system.
tabishop
Appreciate the quick response. Are you saying that the Wifi6E signal won't extend to non-wifi6e satellites or the satellites won't talk to the wifi6e router even for the 2.4ghz signal used by cameras etc.?
Dec 10, 2021Guru - Experienced User
