Chuck_M
Nov 07, 2019Mentor
Is there a Beta Tester Community for AX-6000?
Is there a beta tester community for the AX-6000 like there was for the RBK-53? If so, can I get info on how to apply? Thanks
Nov 07, 2019Guru - Experienced User
Just found the beta forum it's under the
- Connected Home Products - Beta Firmware section. In same section with the Orbi AC.
- Christian just posted there 2 days ago.
For users interested in beta FW for the Orbi AX, contact Christian_R for application requests.
Chuck_M wrote:Is there a beta tester community for the AX-6000 like there was for the RBK-53? If so, can I get info on how to apply?
Thanks
- Chuck_MNov 08, 2019Mentor
Thanks for this.... It appears that if you are a Beta Tester for one model, you are a beta tester for all.
Great stuff!- ekhalilNov 09, 2019Master
There are a number of big features that are still to be implemented in Orbi AX which I think that Netgear will want to beta test before release.
Features like Circle and Bitdefender are nice widely used features in Orbi Gen 1 and I'm sure will soon be added to Orbi AX.
- sabeensNov 10, 2019Aspirant
i'd imagine that beta forum is only visible to beta testers. I messaged to begin the process but i'd imagine slow response with the holiday weekend, understandably so. Do hope i can check out the last beta soon though, getting quite fedup with the broken streaming bugs i'm having.
- FURRYe38Nov 10, 2019Guru - Experienced User
To gain access to the NG community forum beta site, please send a PM to Christian_R
sabeens wrote:i'd imagine that beta forum is only visible to beta testers. I messaged to begin the process but i'd imagine slow response with the holiday weekend, understandably so. Do hope i can check out the last beta soon though, getting quite fedup with the broken streaming bugs i'm having.
- FURRYe38Nov 12, 2019Guru - Experienced User
New FW availalbe if anyone wants to give it a go:
