Chuck_M
Nov 07, 2019Mentor
Is there a Beta Tester Community for AX-6000?
Is there a beta tester community for the AX-6000 like there was for the RBK-53? If so, can I get info on how to apply? Thanks
Nov 07, 2019Guru - Experienced User
Just found the beta forum it's under the
- Connected Home Products - Beta Firmware section. In same section with the Orbi AC.
- Christian just posted there 2 days ago.
For users interested in beta FW for the Orbi AX, contact Christian_R for application requests.
Chuck_M wrote:Is there a beta tester community for the AX-6000 like there was for the RBK-53? If so, can I get info on how to apply?
Thanks
Chuck_M
Nov 08, 2019Mentor
Thanks for this.... It appears that if you are a Beta Tester for one model, you are a beta tester for all.
Great stuff!
- ekhalilNov 09, 2019Master
There are a number of big features that are still to be implemented in Orbi AX which I think that Netgear will want to beta test before release.
Features like Circle and Bitdefender are nice widely used features in Orbi Gen 1 and I'm sure will soon be added to Orbi AX.
