GregS_from_MI
Apr 22, 2023Apprentice
Is there a network solution for 860RBR
First off, I am NOT a network guy so if my question has no solution then let me know. I have an 860RBR and one satellite. I just upgraded my ISP modem to Gig service. When I connected directly f...
Apr 23, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
IF your ISP modem has a router, then yes you could put a switch behind the modem in parallel and connect other devices to this switch while the Orbi is connected to the modem.
With the LAN ports on the Orbi being 1Gb, you'll not ever see much over 940Mpbs on the down. To get anything over this, the 9 series Orbi has 2.5Gb port in back.
