GregS_from_MI
Apr 22, 2023Apprentice
Is there a network solution for 860RBR
First off, I am NOT a network guy so if my question has no solution then let me know. I have an 860RBR and one satellite. I just upgraded my ISP modem to Gig service. When I connected directly f...
GregS_from_MI
Apr 23, 2023Apprentice
The modem is Hitron which has a 2.5Gbps connection currently to my router. I has wondering if a switch with (3) 2.5Gbps ports would work. So one port (in) would be from the modem, one port would then go to the Orbi 860 and the last port to my desktop.
Apr 23, 2023Guru - Experienced User
IF the Htron has a built in router, yes you could. However if the Hitron is only a modem with 1 port, then no.
