GregS_from_MI
Apr 22, 2023Apprentice
Is there a network solution for 860RBR
First off, I am NOT a network guy so if my question has no solution then let me know. I have an 860RBR and one satellite. I just upgraded my ISP modem to Gig service. When I connected directly f...
GregS_from_MI
Apr 23, 2023Apprentice
The modem is Hitron which has a 2.5Gbps connection currently to my router. I has wondering if a switch with (3) 2.5Gbps ports would work. So one port (in) would be from the modem, one port would then go to the Orbi 860 and the last port to my desktop.
Apr 24, 2023Guru - Experienced User
What model hiltron is it?
- GregS_from_MIApr 24, 2023Apprentice
It doesn't matter at this point. The only way I could have the solution I would like is to spend another $1000 on the 960. My pockets aren't that deep.
- plemansApr 24, 2023Guru - Experienced User
If the hiltron is a gateway and not just a modem, there's fairly cheap 2.5gig switches. I bought one for under a $100 and it works great. But that solution only works if the hiltron is a modem/router combo device. Not if its a modem only.
Which is why I ask.
- GregS_from_MIApr 24, 2023ApprenticeNope, just a modem. I'll wait until my ISP (I hope I'm not pushing up dandelions by then) has 10G service before I invest in a comparable 960.:-)
