ant
Sep 15, 2021Prodigy
Is there a way to disable firmware's autodownload and autoupgrade in Netgear Orbi RBK753S-100NAS?
Hello. I was unhappy that Netgear gave me its (new/lat)est firmware on Monday. I didn't ask for it. I do check for firmwares manually. :( Thank you for reading and hopefully answering soon. :...
ant
Sep 15, 2021Prodigy
FURRYe38 wrote:You can try this:
https://community.netgear.com/t5/Orbi-AX/RBK750-Series-Firmware-Update-v4-6-3-7/m-p/2130584#M18586
Thanks. I can't get telnet option to show in debug web page. I upvoted and left a c ommented in https://community.netgear.com/t5/Idea-Exchange-For-Home/Stop-unscheduled-firmware-updates-in-Orbi-AX/idc-p/2140583.
Sep 16, 2021Guru - Experienced User
Did you downgrade to that version of FW? Telnet is supposed to be there.
Do you have a 2ndary router on hand by chance?
- antSep 16, 2021Prodigy
FURRYe38 wrote:Did you downgrade to that version of FW? Telnet is supposed to be there.
No to both. If I use the older version, then Netgear will still autoupgrade it when online though.
- FURRYe38Sep 16, 2021Guru - Experienced User
Not if you do this after downgrading:
