foxbrady
Dec 21, 2021Aspirant
Is there a way to make RBR850 satellite connect to closest access point?
3 of my 4 access points are wired. The 4th one (Shop) is closest to the "Upstairs" AP on the list below, however, it shows that it is connected to the router with poor signal (it's really far away). ...
- Dec 27, 2021
NG has a wireless bridge:
https://www.netgear.com/business/products/wireless/wireless-airbridge/wbc502.aspx
Dec 21, 2021Guru - Experienced User
RBRs are not supported as RBS.
CrimpOn
Thanks for catching the discrepancy. From the context, I had thought it was a simple typo. Since it currently is showing a "Poor" connection as a satellite, my guess is that it really is a satellite. Will be interesting to see.
