foxbrady
Dec 21, 2021Aspirant
Is there a way to make RBR850 satellite connect to closest access point?
3 of my 4 access points are wired. The 4th one (Shop) is closest to the "Upstairs" AP on the list below, however, it shows that it is connected to the router with poor signal (it's really far away). ...
- Dec 27, 2021
NG has a wireless bridge:
https://www.netgear.com/business/products/wireless/wireless-airbridge/wbc502.aspx
CrimpOn
Dec 21, 2021Guru - Experienced User
In the original (2016) Orbi, the Advanced WiFi Settings provided a toggle to enable/disable "Daisy Chain". It appears this choice was removed fromthe 850 series product. (At least it is not found in the User Manual. You could check Advanced Settings and verify this.)
My first step would be to power down the shop satellite. wait a couple of minutes, then power it on again. Perhaps it detected the Orbi router signal first and quit looking for other backhaul paths.
It is fortunate that Orbi satellites are portable. It would be an interesting experiment to temporarily relocate the shop satellite to be in the same room as the desired satellite connection and see if it connects there.
Orbi satellites 'fall back' to 2.4G backhaul when the 5G WiFi signal is not strong enough to maintain a good or fair connection. (i.e. really weak). Would this shop have metal walls? Or foil backed insulation in the walls? How far away is the shop?
I use a "WiFi Analyzer" app on my Android phones and tablets to display the signal strength of WiFi access points. (my own and nearby neighbors). (There must be 8-10 popular apps. I like the one by Kevin Yuan. The others are most likely very similar.) Can you open such an app in the shop? It should display your Orbi WiFi name (SSID) for each Orbi device (on both 2.4G and 5G channels. The shop satellite will have a strong signal inside the shop (maybe -30db or so). What do the other Orbi access points measure?
The backhaul signal will be a WiFi access point on channel 157 (in the US) with no SSID ("? mark") How strong is it?
Sorry about all the questions. I ramble a lot.
foxbrady
Dec 23, 2021Aspirant
Thank you for the reply!
I'll test the signal and then move the shop satellite close to the upstairs satellite to see if it connects/meshes with it.
The shop is metal and stone, yes. A total of two stone walls, one metal, and 3 sheet rock walls. It has worked very well for at least a year. Nothing has changed, which is what's so frustrating. I've reset and power cycled it several times, BTW.
I'll try your suggestion today and report back. Again, thanks for your help!
- FURRYe38Dec 23, 2021Guru - Experienced User
Stone and such will impact wifi signal for sure. I'd get a wired LAN cable out there if possible.
- foxbradyDec 23, 2021Aspirant
It appears the shop door (insulated metal 20' x 12') is effecting the signal quite a bit. Trust me, if I could run a hard line, I would have. :-)
