foxbrady
Dec 21, 2021Aspirant
Is there a way to make RBR850 satellite connect to closest access point?
3 of my 4 access points are wired. The 4th one (Shop) is closest to the "Upstairs" AP on the list below, however, it shows that it is connected to the router with poor signal (it's really far away). ...
- Dec 27, 2021
NG has a wireless bridge:
https://www.netgear.com/business/products/wireless/wireless-airbridge/wbc502.aspx
CrimpOn
Dec 21, 2021Guru - Experienced User
In the original (2016) Orbi, the Advanced WiFi Settings provided a toggle to enable/disable "Daisy Chain". It appears this choice was removed fromthe 850 series product. (At least it is not found in the User Manual. You could check Advanced Settings and verify this.)
My first step would be to power down the shop satellite. wait a couple of minutes, then power it on again. Perhaps it detected the Orbi router signal first and quit looking for other backhaul paths.
It is fortunate that Orbi satellites are portable. It would be an interesting experiment to temporarily relocate the shop satellite to be in the same room as the desired satellite connection and see if it connects there.
Orbi satellites 'fall back' to 2.4G backhaul when the 5G WiFi signal is not strong enough to maintain a good or fair connection. (i.e. really weak). Would this shop have metal walls? Or foil backed insulation in the walls? How far away is the shop?
I use a "WiFi Analyzer" app on my Android phones and tablets to display the signal strength of WiFi access points. (my own and nearby neighbors). (There must be 8-10 popular apps. I like the one by Kevin Yuan. The others are most likely very similar.) Can you open such an app in the shop? It should display your Orbi WiFi name (SSID) for each Orbi device (on both 2.4G and 5G channels. The shop satellite will have a strong signal inside the shop (maybe -30db or so). What do the other Orbi access points measure?
The backhaul signal will be a WiFi access point on channel 157 (in the US) with no SSID ("? mark") How strong is it?
Sorry about all the questions. I ramble a lot.
foxbrady
Dec 23, 2021Aspirant
Not very strong with the shop door shut, which is probably why it has worked so well for so long and I just didn't realize it was b/c of the door.
If I were to move the AP that I want it to mesh with, closer, so it only has to go through 1 sheet rock wall, metal, and 2 stone walls - would that help at all? The way it is set up now, there's 3 sheet rock walls, metal, and 2 stone walls.
- CrimpOnDec 23, 2021Guru - Experienced UserThe metal is the killer. Can you aim over or around the door?
