foxbrady
Dec 21, 2021Aspirant
Is there a way to make RBR850 satellite connect to closest access point?
3 of my 4 access points are wired. The 4th one (Shop) is closest to the "Upstairs" AP on the list below, however, it shows that it is connected to the router with poor signal (it's really far away). ...
- Dec 27, 2021
NG has a wireless bridge:
https://www.netgear.com/business/products/wireless/wireless-airbridge/wbc502.aspx
foxbrady
Dec 23, 2021Aspirant
Not very strong with the shop door shut, which is probably why it has worked so well for so long and I just didn't realize it was b/c of the door.
If I were to move the AP that I want it to mesh with, closer, so it only has to go through 1 sheet rock wall, metal, and 2 stone walls - would that help at all? The way it is set up now, there's 3 sheet rock walls, metal, and 2 stone walls.
CrimpOn
Dec 23, 2021Guru - Experienced User
The metal is the killer. Can you aim over or around the door?
- foxbradyDec 23, 2021AspirantI can try
Is the front the strongest direction?- FURRYe38Dec 24, 2021Guru - Experienced User
Any windows in this buliding by chance?
I'd check into getting a buried or hung LAN cable out to this remote location then you'd be set.
- foxbradyDec 26, 2021AspirantThere are windows but they're farther away.
What about an outdoor antenna? I can put on the outside of the shop and run cat 6 through the shop stone and metal. That way the meshing AP in the house only has to go through one layer of stone and some sheet rock. Does Netgear make anything like that? I know Ubiquity makes an AC antenna.
