foxbrady
Dec 21, 2021Aspirant
Is there a way to make RBR850 satellite connect to closest access point?
3 of my 4 access points are wired. The 4th one (Shop) is closest to the "Upstairs" AP on the list below, however, it shows that it is connected to the router with poor signal (it's really far away). ...
- Dec 27, 2021
NG has a wireless bridge:
https://www.netgear.com/business/products/wireless/wireless-airbridge/wbc502.aspx
foxbrady
Dec 26, 2021Aspirant
There are windows but they're farther away.
What about an outdoor antenna? I can put on the outside of the shop and run cat 6 through the shop stone and metal. That way the meshing AP in the house only has to go through one layer of stone and some sheet rock. Does Netgear make anything like that? I know Ubiquity makes an AC antenna.
Dec 27, 2021Guru - Experienced User
