unioncorps's avatar
Jul 28, 2023
Is there any benefit to have a wired backhaul for an Orbi Mesh system?
Hello everyone,
Apologize for the lengthy post in advance, but wanted to give some background first.
Product: 1 wireless RBR750 router, 2 satellites RBS750
Home Size: 2 story, 4100 sq ft
Current Orbi Placement: see attached layout
Current Internet Speed: Xfinity Internet only - 800 Mbps down/20 Mbps up
Although the pictorial may indicate otherwise, the network topology is star - both satellites are connected to the router and are displaying a 'Good' 5Ghz connection status (at least in the web UI). Wifi devices that are close to the satellites get roughly 700-750 Mbps. Being close to the router as I type on my laptop, I'm getting speeds around 850 Mbps.
With the current placement I have, I've tested the download speeds but wanted to see if they're 'normal' or what you'd expect. All upload speeds were the same regardless at 22ish Mbps.
  • T1: Connected to Satellite 1, 500-550 Mbps down
  • T2: Connected to Satellite 1, 500-550 Mbps down
  • T3: Connected to Satellite 2, 450-500 Mbps down
  • T4: Connected to Satellite 2, 500-550 Mpbs down
Each of the satellites are roughly 25 feet from each other as well as the router (line of sight distance).
So 3 questions for you all:
1. If these decreased speeds are to be expected because of distance, would having an wired backhaul using MoCA help at all? I realize the Orbis use a triband and the wireless backhaul is on a dedicated band, where if you freed that up via wired, you still wouldn't be able to use that band to help with the wifi speeds - but am not sure if there is any benefit to using MoCA in this case.
2. Do you think the Orbi satellite signals are overlapping one another where the device doesn't know which to connect to which impacts speed at the satellites? I know there's speed loss the further you go, but was not expecting the loss to be this much (again, unsure if this is considered 'normal').
3. Is there any better optimal placement of the satellites? I want to leave the router in my office, since that's where my main internet is coming in from the house.
  • CrimpOn's avatar
    CrimpOn
    There is some  evidence to suggest that a modern MoCA installation could provide a true "gigabit" connection between router and satellites:
    https://mocalliance.org/about/faqs.php#:~:text=How%20fast%20can%20MoCA%20go,1%20Gbps%20actual%20data%20rates.
    This would likely improve the throughput, but how much remains to be seen.  Only devices supporting WiFi6 (802.11ax) are likely to benefit.
    An easy test would be to purchase a couple of 100ft. Ethernet patch cables (Amazon has them for under $20US).  If the satellites perform better when linked directly with cable, then MoCA might be a solution.
    • unioncorps's avatar
      unioncorps
      Guide
      CrimpOn thanks!
      The debate I've been reading is that since Orbi already has a dedicated triband that is reserved strictly for a wireless backhaul to communicate with other satellites in the network, establishing a wired backhaul (whether MoCA or true ethernet) wouldn't help any since you won't get any added bandwidth from freeing up that wireless backhaul band and can't use it anyway.
      My impression around mesh technology is that regardless of where you go in the home (assuming the mesh is setup correctly), you'd still achieve consistent speeds throughout even at the ends of the home furthest from the router via the satellites. For example, knowing that there are a ton of more factors to consider but for simplicity sake let's ignore for now, if I'm paying for 800Mbps down I would expect to see speeds consistently close to 800 Mbps everywhere I had a connected satellite and throughout the home.
      • FURRYe38's avatar
        You could see that if you had 4x4 MIMO supporting devices.
        Wired ethernet devices should see to speed speeds though.
  • FURRYe38's avatar
    You could reduce the RBS count by one for that size of home.
    Though the RBS are on different floors from the RBR, the one RBS on the 1st floor RBS would be too close the the RBR and there would be too much wifi signal over lap here.
    Ethernet connected RBS is recommended if the home supports it:
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
    Not sure about MoCA, however I've seen others post about it. Possible it could work if done right.
      unioncorps
      Guide
      Thanks! Previously, I did try taking out 1 satellite in the equation and moved the existing one toward the center of the house on the first floor in the foyer. When connecting to Wifi via the satellite from the master bedroom or in the dining room, I seem to get lesser speeds like only 400-450 Mbps down. Seems having 2 satellites gives me better speeds but still not to what I'm paying for - I'd be happy with consistent speeds of 700-750 Mbps.
      Should satellites be on the same floor vs. different floors? And if so, is it better to have them on the 2nd floor vs. 1st and people on the 1st floor can still get a good speed?
      • FURRYe38's avatar
        You can have RBS on different floors, just distance between each other and the RBR is important:
        30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
        Be aware that you may not or probably wont' see anything near 700Mpbs or over this on WiFi. Due to limitations on wifi devices and 2x2 MIMO support, most wifi devices top out at around 400-600mpbs depending. 4x4 MIMO devices can see over 700Mpbs in certain configurations. What your seeing is still great speeds, even with one RBS deployed.
        https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
        https://www.duckware.com/tech/wifi-in-the-us.html
