kirkmc
Oct 22, 2022Guide
Is there anyway to get devices to connect to the nearest satellite?
I have MetGear Orbi system with a router and three satellites. One of the satellites is in my TV room, which has four Sonos devices. None of these devices connect to that sate, but connect to one down...
CrimpOn
Oct 24, 2022Guru - Experienced User
kirkmc wrote:
I have MetGear Orbi system with a router and three satellites. One of the satellites is in my TV room, which has four Sonos devices. None of these devices connect to that sate, but connect to one downstairs. It would seem more efficient if they connected to the that’s just a few feet away.
As others have pointed out, the device determines which WiFi access point it will connect to. When a mesh system starts up, the base unit (in this case the Orbi router) usually begins broadcasting the WiFi SSID first. Devices which are waiting for an SSID to appear (that they recognize), may connect to this access point and then stop searching. Devices which are intended to be mobile (i.e. to "roam") may have software that constantly searches for a better connection. Devices which are expected to remain in the same place (TVs, speakers, cameras, garage door openers, etc. etc.) may quit looking.
Something that people have tried is to deliberately power the device off and back on, which will force it to search for a WiFi connection again. If the nearby satellite has a better connection, the device may choose it.
