bjosh
May 16, 2022Follower
Is there ETA for the fix also is NG going to push the fix
Is there ETA for the fix also is NG going to push the fix since we are unable to login to the router through the browser or app.
May 16, 2022Guru - Experienced User
Might contact NG support and see if they can help with out a reset.
May 17, 2022Guru - Experienced User
I don't think it's the Fw that's the problem, more like how its being deployed thru auto updates. I and others have had v.2 loaded since before NG started pushing the same version via AU. Ours was loaded manually. Have not seen any problems accessing the RBRs web page. Also maybe some problems in auto updating systems from older versions of v4 to new v.4 versions as well. I believe mostly this is a AU issue that hasn't been fully addressed or tested fully by NG in how AU works.
- claudiutMay 17, 2022Apprentice
I can confirm that loading the firmware (v4.6.8.2) manually works (so far) without issues. I'm able to access the router and satellites through web interface and Orbi app.
To be completely honest I'm not 100% convinced it's not a FW issue as FURRYe38 implies, but in the end, it doesn't even matter. NG should get their s^#% together and fix this mess that goes on for way too long.
- FURRYe38May 17, 2022Guru - Experienced User
Historically AU has seen many issues over time, even on Orbi AC models. Not the first time AU has broke users systems.
NG will hopefully take heed this time. I agree, they messed up big time. Hoping they will do something.
Keep your v.2 FW files on hand.
It only a small part. AU system we believe it's it own beast that out of control.
Never mentioned putting fault at users configurations. This event is certainly on NG. I only explained that some of us who had v.2 already loaded prior to NGs AU event weekend before last didn't' see problems. This doesn't mean this is a user configuration issue or was directed at users configurations.
