donawalt
Feb 04, 2021Hero - Experienced User
Is this a good topology?
I am setting up a network in a large house - 4 floors. I added a 3rd satellite so each floow has a router or satellite, well spaced. Everything looks fine regarding speed, errors, issues etc. I s...
Feb 04, 2021Guru - Experienced User
I guess that works too though the one RBS will be handling lots of traffic since it's the only one connected to the RBR. If it seems to work for you then why not.
donawalt
I didn't set it up that way, I just added the Satellites one by one per the setup documentation. Is there a way I can influence/change the topology? Should I turn off the Floor 2 satellite, let the other 2 connect directly to the RBR, then turn it back on for example? Or just leave it be?
- FURRYe38Feb 04, 2021Guru - Experienced User
Ya try to power the remote or farther RBS on first before the closer one.
