Meche697
Feb 04, 2025Aspirant
Isolate 2.4/5.0 and latest firmware cheat sheet
There used to be a way of SPLITTING the two bands into separate SSIDs via Telnet. This is no longer the case. There is equipment, like cameras, door locks, etc, that I want on a different SSID. I rec...
CrimpOn
Feb 04, 2025Guru - Experienced User
most models with v7 firmware now include the "IoT" channel which can be set to 2.4G only.
Meche697
CrimpOn, Do I need to log into the IoT network to access the accessories or will it connect via my main connection?
I'm also now seeing a WiFi connection SSID (ORBI) in addition to my regular SSID that I've had for years
- CrimpOnFeb 04, 2025Guru - Experienced User
The IoT network needs to be enabled using the Orbi administration. (I prefer the web administration over the Orbi 'app')
Enter the model number of the router on this page to find the User Manual:
