CW_2023
Jan 25, 2024Aspirant
Issue after Software update for RBR750 and login issues
Hi I just recently updated the firmware for my Orbi Satellite RBR750 (V4.6.14.92). After that, all connected devices information in the Orbi Apps are gone and now it is just shown as "N/A" and "...
Jan 25, 2024Guru - Experienced User
Is the RBR using same version of FW? What version of FW is loaded there?
Have you powered OFF the RBR and RBS for one minute then back ON?
For the RBR750 and RBS750, there is newer FW available:
RBS need to be updated first then RBR lastly.
- CW_2023Jan 28, 2024AspirantI rebooted using the apps and also swtiched off the power for more than 1 min. I also re installed my Orbi App. It is still not working as before we updated the software. The product is below
https://netgearstore.sg/products/orbi-rbs750-wifi-6-mesh-system-add-on-satellite?variant=32182182805615¤cy=SGD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&utm_term=&utm_campaign=Performance+Max&utm_source=adwords&utm_medium=ppc&hsa_acc=9761578850&hsa_cam=17412698141&hsa_grp=&hsa_ad=&hsa_src=x&hsa_tgt=&hsa_kw=&hsa_mt=&hsa_net=adwords&hsa_ver=3&gad_source=1&gclid=CjwKCAiA8NKtBhBtEiwAq5aX2O7xyLRnCMX_DNZfufuAFV6Kv9jNxFdK1bZ9xouI9eAMosgYxzGxXBoCSx0QAvD_BwE- FURRYe38Jan 28, 2024Guru - Experienced User
Factory reset and setup from scratch:
Walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
