mdn1234
May 15, 2024Aspirant
Issue connecting pc to satellite via ethernet
Hi All Everything had been working fine for years and suddenly my pc cannot connect anymore to my Orbi RBS350 satellite via Ethernet. Some details: - Computer can connect via ethernet to the...
- May 16, 2024
Just solved the problem:
In the admin page of the router, Basic > Internet > Routeur MAC Address. "Use Computer MAC Address" was selected.
I switched to "Use Default Address" and the computer directly reconnected to the network.
Then I switched back to "Use Computer MAC Address" and it keeps working.
Interesting bug with the router... to put it politely!
Best
mdn1234
Yes and I shared the link to this thread on Reddit when I created it.
Latest test with ethernet cable directly to the base demonstrates that pc works well so still having a pending Orbi issue to solve 🙂
Best
May 15, 2024Guru - Experienced User
Does this happen with other devices connected to the RBS via ethernet as well?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a factory reset and setup from scratch been performed since last FW update? https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2356834/highlight/true#M52575
- mdn1234May 16, 2024Aspirant
Best
- FURRYe38May 16, 2024Guru - Experienced User
Default MAC Address would be recommended. Unless your ISP has some specific needs for using a PC MAC Address.
Probably on next reboot would see the change so may not be a bug.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- mdn1234May 17, 2024Aspirant
Yes I have eventually left it in the Default MAC address mode as it was bugging again. I don't know why this option was set up like that, maybe following the firmware update.
Anyway, it works fine now, thank you!
