Platanax's avatar
Platanax
Issue on RBR850 - Reccuring crash of the router
Hi, I have an issue since a few days : my RBR850 has reccuring crashes with no explanation (crashes every 1 or 2 days) Firmware : V7.2.6.21_5.0.20  Configured as "router"   Symptoms : The route...
  • michaelkenward's avatar
    Nov 04, 2023
    Platanax wrote:
    Hi,
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
