Yahey
Dec 13, 2021Aspirant
Issue to have ORBI app detecting my installed ORBI network
Hello Community, ** As requested, I'm opening a dedicated thread for my issue ** I have an issue to have ORBI app detecting my installed ORBI network. My ORBI network is working just fine...
Yahey
Dec 14, 2021Aspirant
Hello,
As option 1 is not possible on my ISP box and I need the routing functionnalities (option 3), I went for option 2 (DMZ for not having kind of double NAT).
Unfortunately, the issue remains unchanged.
I uninstalled/reinstalled the app.
My ISP box has no WiFi activated.
Dec 15, 2021Guru - Experienced User
Try isntalling Orbi app on a different device.
Try option#2 in the suggested items for avoiding double NAT.
Yahey wrote:
Hello,
- YaheyDec 18, 2021Aspirant
Hi,
I installed the app on a Samsung Galaxy S8 (instead of a Google Pixel 5).
Unfortunately, I have the exact same behavior ... :(
- FURRYe38Dec 18, 2021Guru - Experienced User
I reommend you post here about this and contact NG support:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Hi,
Thank you for the hint but I am not able to contact directly NG agents.
After entering my serial number and trying to open a case, NG web sites says I have to deal with NG Community. :(
Post over in the Orbi app forum...will get you in contact wtih a forum moderator.
- YaheyDec 21, 2021Aspirant
Hi, Done. thx
