nerdfrenzy
Jun 23, 2024Aspirant
Issue with Connecting Google Nest Cameras
Hi, I have recently updated my Orbi Router and Satellites to firmware version V7.2.6.31_5.0.24 and since doing that I am unable to connect new Google Nest cameras or re-add Google Nest Cameras th...
Jun 24, 2024Guru - Experienced User
Are you using same SSID name and PW as before?
Same channels as well?
Try using the IoT network to get the NEST cameras connected?
What is the distance between the router 📡 and satellite(s)🛰️?
Has a power off for 1 minute then back ON with the ISP modem and router and RBS been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- nerdfrenzyJun 24, 2024Aspirant
Thanks for the reply
I had tried all the things you suggested prior to putting up the post. It seems that it was an issue with Google as today everything has started to work with the 2 Nest cameras that were having issues
- FURRYe38Jun 25, 2024Guru - Experienced User
Glad you got it working. Please leave feedback next time for questions presented. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
