Lewis2e
Jan 03, 2023Star
Issues connecting AP to Orbi network
I have an Orbi network (RBR750 and two RBS750 satellites). In itself, this works great. I want to connect an access point to the network. I am trying to use a Netgear WAX204 in AP mode. The AP is...
- Jan 03, 2023
Once its attached to the router and has its own ip address assigned, can you set it with a reserved ip address?
Once thats done, power it off and try connecting it directly to the satellite and powering it on.
If that works, then try it through the switch.
Jan 03, 2023Guru - Experienced User
I know this sounds stupid but that AP has a router mode and an access point mode. Have you checked to ensure its actually in access point mode?
https://www.netgear.com/support/product/wax204.aspx
Lewis2e
Jan 03, 2023Star
Hi
Not at all, I appreciate any efforts to help. And I apprecaite why you are asking the question, as I know what I am describing sounds like I've left it in router mode.
I can confirm that it is definitely in AP mode. It actually has three modes - (1) Router (2) AP and (3) Bridge. It's in AP mode.
I'll try and get a screenshot (just have to jump on my other PC).
