IndianGeek
Oct 09, 2023Follower
Issues connecting to certain sites with RBK852
Hi, For the past while, I've been facing issues connecting to certain sites such as Wikipedia and Yahoo Mail through the Orbi network. Wikipedia gives a "connection timed out" error over bot...
Oct 09, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is the RBR using a Dynamic or static IP address configuration for AP mode?
While in AP mode, Orbi is just passing thru data from connected devices to the host router. Would not be causing problems with web sites. I would check your host router and ISP modem for configuration issues here.
