Beharr
Aug 10, 2021Aspirant
issues Orbi6 satellite
Major issues with the main port on the RBR850 Orbi Satellite 6. When the lights flicker for 10 seconds due to storms happened twice the Orbi is shot, althought its reset and rebooted many times its ...
Aug 10, 2021Guru - Experienced User
How do you not have this on a surge protector or even a half decent power supply?
If you're having that much power issues, I'd have all my expensive electronics on a backup power supply.
The first $300 router I lost due to power surges caused an immediate purchase of a UPS.
Beharr
yes it was on its own high powered commericial grade surge protector both times. Also the netgear modem is on its surge protector no other equipment was affected only the ORBI
