RH3's avatar
RH3
Issues with Cisco Anyconnect VPN and CBR750 with RBS750 Satellite
Hello,
I am having issues with my xfinity internet provider and my orbi system when working from home with a cisco anyconnect VPN.  The WIFI has been noisey/ lagging, it has dropped out when another device turns on and connects to our wifi, it can be extremely slow (definitely not what we pay for at 1000Mbps), or has dropped connection completely - all intermittently at times.  We have been able to manage, but now I am not able to connect to WIFI at all.
The Orbi app says I have internet and the satellite is online - all green on the network map.  But, the internet provider and app says my Netgrear CBR750 is offline.
I think it has something to do with VPN, but I'm not sure.  Please let me know your thoughts.
Modem/ Router
CBR750 - V4.6.14.4
Satellite
RBS750 V4.6.14.3
  • FURRYe38's avatar
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the CBR?
    Do you have any problems with out using the VPN?
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • RH3's avatar
      RH3
      Thanks for the quick reply Furry.  Here are some answers to your questions:
      Home size = 2,000sqft (circa 60's)
      Distance to satellite 38ft
      I haven't checked with the RBS turned off.  We have all wireless devices.
      Looks like it is working better this afternoon with VPN off.
      Looks like 5 or 6 WIFI neighbors.
      I have no event logs, but here is the cable connection log
      Cable Diagnostic
      Status:   Poor
      Action:
      [Partial Service]
      If the Partial Service mode does not go away within a few hours (Click the Refresh button after each step):
      1) Make sure the coaxial cable is tightly connected.
      2) Remove any unnecessary splitters.
      3) Replace any required ones.
      4) Contact your service provider for troubleshooting help.
      Internet Access:
      Downstream Status:
      Partial Service:
      Cable modem is in partial service mode. Your service provider might be under maintenance. Most of the time it won't affect your traffic and will automatically clear when work is complete.
      Downstream Power Level:
      Downstream SNR:
      Upstream Status:
      Startup Procedure
      Procedure
      Status
      Comment
      Acquire Downstream Channel
      507000000 Hz
      Locked
      Connectivity State
      Ok
      Operational
      Boot State
      Ok
      Operational
      Security
      Enabled
      BPI+
      IP Provisioning Mode
      Honor MDD
      honorMdd(4)
      Downstream Bonded Channels Partial Service
      Channel
      Lock Status
      Modulation
      Channel ID
      Frequency
      Power
      SNR
      Correctables
      Uncorrectable
      1
      Locked
      QAM 256
      2
      489000000 Hz
      5.8 dBmV
      37.6 dB
      0
      0
      2
      Locked
      QAM 256
      3
      495000000 Hz
      5.8 dBmV
      38.6 dB
      19
      0
      3
      Locked
      QAM 256
      4
      501000000 Hz
      6.0 dBmV
      37.6 dB
      38
      20
      4
      Locked
      QAM 256
      5
      507000000 Hz
      5.8 dBmV
      38.6 dB
      0
      0
      5
      Locked
      QAM 256
      6
      513000000 Hz
      5.9 dBmV
      37.6 dB
      0
      0
      6
      Locked
      QAM 256
      7
      519000000 Hz
      6.0 dBmV
      37.6 dB
      50
      52
      7
      Locked
      QAM 256
      8
      525000000 Hz
      5.9 dBmV
      37.6 dB
      41
      68
      8
      Locked
      QAM 256
      9
      531000000 Hz
      5.5 dBmV
      37.6 dB
      43
      62
      9
      Locked
      QAM 256
      10
      537000000 Hz
      6.0 dBmV
      37.6 dB
      52
      60
      10
      Locked
      QAM 256
      11
      543000000 Hz
      6.0 dBmV
      37.6 dB
      57
      49
      11
      Locked
      QAM 256
      12
      549000000 Hz
      6.0 dBmV
      37.6 dB
      40
      53
      12
      Locked
      QAM 256
      13
      555000000 Hz
      6.1 dBmV
      37.3 dB
      49
      63
      13
      Locked
      QAM 256
      14
      561000000 Hz
      6.4 dBmV
      37.3 dB
      6
      0
      14
      Locked
      QAM 256
      15
      567000000 Hz
      6.5 dBmV
      37.3 dB
      0
      0
      15
      Locked
      QAM 256
      16
      573000000 Hz
      6.5 dBmV
      37.6 dB
      0
      0
      16
      Locked
      QAM 256
      17
      579000000 Hz
      6.5 dBmV
      37.6 dB
      0
      0
      17
      Locked
      QAM 256
      19
      591000000 Hz
      6.6 dBmV
      34.4 dB
      1399265
      43194
      18
      Locked
      QAM 256
      20
      597000000 Hz
      6.8 dBmV
      37.6 dB
      0
      0
      19
      Locked
      QAM 256
      21
      603000000 Hz
      7.5 dBmV
      37.6 dB
      0
      0
      20
      Locked
      QAM 256
      22
      609000000 Hz
      7.5 dBmV
      37.6 dB
      0
      0
      21
      Locked
      QAM 256
      23
      615000000 Hz
      7.5 dBmV
      37.3 dB
      0
      0
      22
      Locked
      QAM 256
      24
      621000000 Hz
      7.6 dBmV
      36.8 dB
      7
      0
      23
      Locked
      QAM 256
      25
      627000000 Hz
      7.3 dBmV
      36.1 dB
      4
      0
      24
      Locked
      QAM 256
      26
      633000000 Hz
      7.1 dBmV
      36.6 dB
      2
      0
      25
      Locked
      QAM 256
      27
      639000000 Hz
      7.1 dBmV
      36.6 dB
      0
      0
      26
      Locked
      QAM 256
      28
      645000000 Hz
      7.0 dBmV
      37.3 dB
      0
      0
      27
      Locked
      QAM 256
      29
      651000000 Hz
      6.8 dBmV
      37.3 dB
      0
      0
      28
      Locked
      QAM 256
      30
      657000000 Hz
      5.9 dBmV
      36.6 dB
      2
      0
      29
      Locked
      QAM 256
      31
      663000000 Hz
      4.5 dBmV
      36.6 dB
      7
      0
      30
      Locked
      QAM 256
      32
      669000000 Hz
      3.0 dBmV
      36.3 dB
      0
      0
      31
      Not Locked
      N/A
      N/A
      0 Hz
      0.0 dBmV
      0.0 dB
      0
      0
      32
      Not Locked
      N/A
      N/A
      0 Hz
      0.0 dBmV
      0.0 dB
      0
      0
      Upstream Bonded Channels
      Channel
      Lock Status
      US Channel Type
      Channel ID
      Symbol Rate
      Frequency
      Power
      1
      Locked
      ATDMA
      8
      5120 Ksym/sec
      16400000 Hz
      45.3 dBmV
      2
      Locked
      ATDMA
      7
      5120 Ksym/sec
      22800000 Hz
      45.8 dBmV
      3
      Locked
      ATDMA
      6
      5120 Ksym/sec
      29200000 Hz
      46.3 dBmV
      4
      Locked
      ATDMA
      5
      5120 Ksym/sec
      35600000 Hz
      46.0 dBmV
      5
      Locked
      ATDMA
      10
      1280 Ksym/sec
      39600000 Hz
      45.3 dBmV
      6
      Not Locked
      N/A
      Unknown
      0 Ksym/sec
      0 Hz
      0.0 dBmV
      7
      Not Locked
      N/A
      Unknown
      0 Ksym/sec
      0 Hz
      0.0 dBmV
      8
      Not Locked
      N/A
      Unknown
      0 Ksym/sec
      0 Hz
      0.0 dBmV
      Downstream OFDM Channels
      Channel
      Lock Status
      Modulation/Profile ID
      Channel ID
      Frequency
      Power
      SNR/MER
      Active Subcarrier
      Number Range
      Unerrored
      Codewords
      Correctable
      Codewords
      Uncorrectable
      Codewords
      1
      Locked
      3
      37
      690000000 Hz
      5.3 dBmV
      37.8 dB
      1108~2987
      0
      0
      0
      2
      Not Locked
      0
      0
      0 Hz
      0.0 dBmV
      0.0 dB
      0~4095
      0
      0
      0
      Upstream OFDMA Channels
      Channel
      Lock Status
      Channel ID
      Frequency
      Power
      1
      Not Locked
      0
      0
      0 Hz
      0.0 dBmV
      2
      Not Locked
      0
      0
      0 Hz
      0.0 dBmV
  • CrimpOn's avatar
    CrimpOn
    RH3 wrote:
    The Orbi app says I have internet and the satellite is online - all green on the network map.  But, the internet provider and app says my Netgear CBR750 is offline.
    The ISP also has an 'app'?
    Purchasing a combination modem/WiFi router is advantageous because:
    • One device takes up less physical space than two.
    • There is one fewer cable in the way.
    • The ISP will not be charging a monthly fee for the cable modem.
    The downside is that now you get to deal with cable modem "issues" in addition to typical home WiFi issues.
    FURRYe38 's advice to look at the cable modem logs is a good place to start.  Cable systems are vulnerable to all sorts of issues, including faulty splitters, breaks in the cable insulation, loose crimps, etc.  In our area, squirrels have been known to mess up cable drops.  Many of these problems are intermittent, which makes them the very devil to diagnose.
    Company VPNs are special to us as users, but not to WiFi routers.  As far as they know, some device on their network asked to connect to a URL on the internet and exchange weirdly encrypted packets of information.  There may be an assumption that this is not a web site because the port number does not match a port typically associated with https, but using port 443 is only a convention - not an absolute rule.
    No WiFi, or no internet?
