cac3893
Nov 28, 2021Aspirant
issues with devices connecting to only router
Good afternoon. I have a Orbi RBR750 and two satelittles. AX4200 is the system. I am having issues with satelittes disconnecting and reconnecting. Also noticing when I do a reboot of the router ...
Nov 28, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, and Traffic Meter and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings.
Try disabling AX mode on the RBR under Basic Tab/Wireless seeings, uncheck the box next to 2.4Ghz.
- cac3893Nov 28, 2021Aspirant
THis is what settings I had. See attached photos. I have charter internet. ARRIS TM1602A modem. My home is 2 stories. about 3800 sq ft. My router is connected to the modem on far end of basement. Then satellite on other end of first floor and the other on 2nd floor mid floor plan. I would say my other neighbors have wifi but not sure on type.
- FURRYe38Nov 28, 2021Guru - Experienced User
"My router is connected to the modem on far end of basement." Basements are not recommnended places for wifi routers. Concrete and steel will cause problems for wifi and inhibit wifi travel.
- cac3893Nov 28, 2021AspirantThat’s the thing though. All devices are actually going to the router in basement vs the satellites that are connected via backhaul to it.
