tabarnes19
Mar 11, 2021Star
Issues with new rbk853 install
I installed a new rbk 853 system last Night in AP mode.. Router is in one corner of house, satellite one 35 feet away in center of house and satellite 2 about 33 more feet away in detached garage. ...
Mar 11, 2021Guru - Experienced User
A diagram or map lay out of your home and where the Orbi units are placed maybe more helpful to us to see how the system is layed out.
What Firmware version is currently loaded? v12 is most current.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
tabarnes19
Mar 11, 2021Star
I updated firmware last night to most current. Attached is diagram. 66 feet or more and multiple walls between router and last sat. At least 33 feet between stations. I made sure to have at least 30 feet.
ARRIS modem spectrum
Nighthawk r9000 x10 serving as router
Orbi as ap
Orbi as ap
- FURRYe38Mar 11, 2021Guru - Experienced User
Is there a model # for the modem?
- tabarnes19Mar 11, 2021StarSorry checked its a new modem. It's a hitron e31n2v1
Does the Orbi app show the RBS connected to each other or both connected at the RBR with you select the Network map?
To be sure the farthest RBS is getting a good signal in your configuration, I would turn the one in the garage OFF for 30 seconds then back ON, it should connect the RBS nearest itself rather than the RBR if you have the RBR output power set to 50%.
- tabarnes19Mar 11, 2021StarIt connects both at startup then goes to daisy chain which I want. Devices in garage will connect to Router some times. Devices right next to router connect to living room..etc.
Well if you have the RBR set to 25% and apply the change, items in the garage should connect to the RBS or other RBS. Are you disabling the devices wifi radio for 5 seconds then back ON to see if they connect to either RBS?
