BlueMoon1801
Aug 30, 2021Follower
Issues with throttling internet speed.
Model: AX4200 WiFi Satellite (RBS750) I'm plugged in via ethernet with my gaming desktop. Just bought this 5 days ago and was working good the first day. Been having problems with it since then wi...
Sep 01, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Armor, AX mode on the RBR and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
