jamescp
Jul 04, 2022Follower
issues with wifi stalling
hello all, i'm having an issue where at times you have to turn off the wifi and then turn it back on to get certain things to load. it seems to mostly be on our iphones. i recently read that the ...
Jul 04, 2022Guru - Experienced User
Using the WAN port on the RBR connected to the Switch?
What happens if you connect the RBR to the PFSense router directly? By passing all switches?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What CAT# LAN cable are you using? CAT5 is recommended.
