WindowWasher
May 30, 2022Follower
It looks like the fix for no access to the web admin pages was applied
I'm having the same problem. It looks like the fix for no access to the web admin pages was applied (I couldn't log in yesterday, now I can), but I can't log into one of my satellites. The router reports that the firmware on the satellite I can't connect to is V4.6.5.14. The satellite I can connect to is at V4.6.8.2 and so is the router firmware. I tried connecting the satellite directly to the router with ethernet and I still can't access it. I want to get the satellite's firmware updated, but I don't know how I can do that if I can't log in.
I'm trying to connect with support, but my units are off software support and they make it very difficult to get support, even when they caused the problem.
1 Reply
Links to review:
If any of this fails, you'll need to contact NG support:
https://my.netgear.com/support/contact.aspx
Good Luck.
