NCoastJack
May 18, 2022Guide
I've seen a "fix in 48 hours" twice now - and no fix.
I've supplied my serial number to support & was told I'd have a fix in 24 hours.
Its over 24 hours. I'm still waiting.
May 18, 2022Guru - Experienced User
You'll need to keep an eye on this:
Or make contact with NG support. This is beyond forum help.
mattg1960
May 20, 2022Star
What's the point of checking status.netger.com?
It just tells us what we already know...our products are not working.
I'm not sure how Netgear is to be taken seriously as a company at this point.
This issue has been unresolved for far too long.
At the least, someone from the company should be posting daily updates on the progress (or lack thereof) of fixing this widespread issue.
- FURRYe38May 20, 2022Guru - Experienced User
Is your system still having problems? If so, you'll need to contact NG support if a factory reset doesn't help.
- mattg1960May 20, 2022Star
The point is simple: I should not have to be resetting my system because of a problem created by Netgear.
I will do so (reluctantly) this weekend because my wife needs Wifi for her job that pays for the house we live in and the food we eat.
Stable internet is critical in the modern age, and Netgear is not holding up their end of the bargain.
Just 3 minutes ago I clicked on this link to reply and saw that my Orbi was rebooting yet again. That means I have random reboots 3, 4, 5, 6 times every day. WTF?
I will reset it tomorrow and hope the system does not brick. If it does, I can only hope that Costco will take it back.
I purchased the system because of good reviews. I paid a premium compared to other companies for the performance and reliability.
Orbi has failed on both counts. I am not an IT engineer...I am paying for Netgear to get it right. Time for them to step up.
Also you can contact NG support and ask for there help. I believe users have mentioned support was able to help regain access with out having to factory reset.
