switters
Dec 24, 2019Apprentice
Just installed Orbi AX: problems with wired and wireless speeds
I just bought an Orbi 6 (RBK852). I put my Xfinity XB6 router in Bridge Mode and deactivated the xFi Pods I had. I went through the setup process for the Orbit 6 and it seemed to work fine. Howe...
Chuck_M
Dec 30, 2019Mentor
it would be good to list the devices you have on your hardwired network... they may be making an issue.
Have you tried to reinstall the app? it may be as simple as that.
