solosys
Aug 07, 2022Aspirant
Just tried an EX8000. Was unable to extended the AX6000 Orbi network
Just tried an EX8000. Was unable to extended the AX6000 Orbi network. Was only able to directly connect to the RBR850 and set up the EX8000 as a WAP. It’s unfortunate it’s unable to extend the Orbi. ...
Aug 08, 2022Guru - Experienced User
What did you do to try to get the EX8000 to connect to the Orbi AX system in extender mode?
Ensure the FW on the EX extender was up to date?
What Firmware version is currently loaded on the Orbi system?
solosys
Aug 08, 2022Aspirant
I'm running V4.6.3.16 on the Orbi. I don't think I'm running the latest on the extender because there was issues with flashing a new version last time. Updating it bricked it last time so I had to manually revert to an older version.
Essentially what happens is that the netgear extender GUI reports that it can't connect to the Orbi network.
