ThomasAndersen
Dec 20, 2021Aspirant
L2TP passthrough Orbi
Hi I can´t connect to my company VPN (L2TP) through my Orbi network. If I use my internet sharing on my phone, it works just fine. What should I enable in my router to get it working?
ThomasAndersen
It is a RBR750, V4.6.5.14_2.0.54.
The internet providers modem is an Icotera I5800.
It worked fine with my previous WIFI routers (Nokia Beacon) from my internet supplier.
I switched WIFI to get better performance.
Dec 20, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Review the "Recommendations" links at the bottom of your post to see if anything may be helpful:
