masterloggie
Jan 06, 2022Tutor
Lack of Customer Suppot For the WiFi 6e 960
I spent over $1700 USD on a system tha did not last a week. Spent 3 hours on the phone and received a router replacement that would not pair with the satellites. Case # 45544395 was started today. Fi...
masterloggie
Jan 07, 2022Tutor
The firmware was manually updated on the router, but the program could not communicate with the satillites when directly plugged into the computer internet port nor did the Orbi program see the satellites when setting in the same room with the router. Thanks for your support.
Assume I will waste another 3 hours of my time with tech support.
Jan 07, 2022Guru - Experienced User
Well still doesn't answer the questions presented...This doesn't help and is wasting time.
You can try this to see if you can update the RBS to same version of FW:
You need to update the RBS before updating the RBR. Keep this in mind for future updates.
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite📡. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite📡. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites 📡 web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites 📡 to the RBR.
Otherwise, you should return the system to place of purchase.
