slayrc
Jan 16, 2020Follower
Lack of indicator light on AX6000
Other than a tiny pin green LED on the back bottom of the unit, you can't tell when it's on. All the advertising pictures, product pictures and system illustrations show a blue LED on the front botto...
Chuck_M
Jan 16, 2020Mentor
Does it light during the power up sequence or when the network gets disconnected?
slayrc wrote:Other than a tiny pin green LED on the back bottom of the unit, you can't tell when it's on. All the advertising pictures, product pictures and system illustrations show a blue LED on the front bottom growing. Never seen a piece of equipment that you can tell is even on, just at a glance. Think we should at least have what you see in the ads. This is really a product design issue.
