Darkknight007
Nov 30, 2020Aspirant
LAG for Dual WAN Orbi RBK 852
How to setup dual wan with link aggregation from two nokia G-140W-F units
Nov 30, 2020Guru - Experienced User
Maybe you can have the LAG enabled and use two different ISP modems:
https://kb.netgear.com/000061324/How-do-I-set-up-WAN-aggregation-on-my-Orbi-WiFi-6-System
Let us know if you find out this works for you.
- Darkknight007Nov 30, 2020Aspirant
Have been trying to setup the LAG/LACP(Step 7) for Nokia G-140W-C & Nokia G-140W-F however not sure how did one achieve dual wan. I have two different ISPs connected to thes modem+router units
- plemansNov 30, 2020Guru - Experienced User
I don't have a RBK852 but my understanding was the WAN port aggregation was single device usage.
Otherwise you'd have the options of load balancing/fail-over like a dual wan router and not a wan port aggregate router.
i sure could be wrong.
- schumakuNov 30, 2020Guru - Experienced User
plemans wrote:... my understanding was the WAN port aggregation was single device usage.
Perfectly correct.
Darkknight007 there is no support for operating multiple WAN connections or multiple WAN devices on any Orbi.
- FURRYe38Nov 30, 2020Guru - Experienced User
First off, try LAG with just one modem if that one modem supports LAG as well. Your modem has to support LAG.
Darkknight007 wrote:Have been trying to setup the LAG/LACP(Step 7) for Nokia G-140W-C & Nokia G-140W-F however not sure how did one achieve dual wan. I have two different ISPs connected to thes modem+router units
