jrk2017
Jul 31, 2020Tutor
Lag spikes and random disconnection
Recently, my family and I decided to buy a new modem and router. We chose the netgear cm11000 and Orbi RBR850 tri-band mesh router. Everything was going smoothly for about two weeks, but out of nowhe...
CrimpOn
Jul 31, 2020Guru - Experienced User
Congratulations on buying the "latest" in Orbi technology.
Unfortunately, thiis is the community forum for the "original WiFi5 Orbi". There is a forum specifically for the "AX" product where the participants are more likely to have experience that will relate to your situation:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
May get a more informed response if you post in that forum.
Good Luck
