TackMan
Jul 03, 2021Tutor
Laptop and PC refuse to connect to satellite, but can connect to Router -- advice?
Hi All, I have a very frustrating experience with one of 2 RBS850 Satellites. The Router reports the connection to both are good, most devices appear to connect to either satellite, and also to ...
Jul 29, 2021Guru - Experienced User
Well actually networking standards is to only have 1 connection per device. I've always used 1 connected on my Macs at a time. Not both.
Possible problem in that either Mac is causing problems with both connections being connected at the same time or Orbi doesn't support having two connections to 1 device at the same time.
raven_au
Jul 30, 2021Virtuoso
FURRYe38 wrote:Well actually networking standards is to only have 1 connection per device. I've always used 1 connected on my Macs at a time. Not both.
Right, having two physical connections to a device is really bad, it can cause really odd problems with ARP address resolution on the local network and some services can get really confused by it.
NFS, for example (and possibly other network file systems), gets really confused by responses coming in on a different network interface to the one the it originated on.
